Set Conditional Visibility in Field Maps Smart Form using a wildcard for domain values
3877
06-01-2021 01:23 AM
CinthiaEichhorn
I am new to Arcade, and  setting the conditional visibility on a Group in the Field Maps Smart Form based on multiple values in an attribute domain.
Those values are:
bone
bone, carcass
carcass
feathers
feathers, bone
I can get the group to display for one value by using DomainName($feature,"mortremains")== "bone"
However, I would like for the group to appear if any of the attribute values have the text "bone" as part of the attribute value.  But, a wildcard option, doesn't seem available.  Tried the ||, but that didn't work either.
Is there a wildcard option in Arcade for the DomainName($feature,"mortremains")== "bone" ?
by Anonymous User
Not applicable
I think you could use the Find function to do this. It'd be something like:
Find("bone", DomainName($feature, "mortremains")) >= 0
I haven't tested this but I think it should work.
by Anonymous User
Not applicable
CinthiaEichhorn
@Anonymous User    This works perfectly.  Thank you!!! 😊😊😊
To help others who may read this, there was also another choice as well:
All three (bones, feathers, carcass)
So the field user has these options:
bone
bone, carcass
carcass
feathers
feathers, bone
I have three groups in the smart form that need to appear for the field user: bones group, feathers group, carcass group depending on what they see once they track the VHF signal.  @Anonymous User 's solution allows the correct groups to display based on their choice.
