Related table without template
1398
06-04-2023 06:50 AM
AntonioPatera
Hello. I have some projects created with Survey123 and I am migrating to Field Maps. So far I had no problems, except for one. There is no template for a table related to the feature layer (see screenshots). How can the problem be solved? One of many bugs?
DustinSellinger
Bumping this up as I'm running into the same issue.  I want to clean up a form input into a yes/no slide but without a template setting the default (never mind that the feature layer also needs to have the same default) the form stays stuck as a selection screen with no value.
