New Field Types (Date only, time only, timestamp offset) available in Field Maps offline?
2746
02-21-2024 03:48 PM
kmsmikrud
I'm wondering when/if the new fields in AGOL (date only, time only) will be available in Field Maps (offline). Is this in the next release by chance?
If not (yet) what would you suggest as the best workaround for time (HH:MM) military time?
Thanks!,
Kathy
MitchellGrafstein
It's not completed, yet, but I have an enhancement request already in the works for this with Esri.  I may post it as a new idea, as it also involves the other new data types and it involves other offline workflows - so it will probably be posted in AGOL as an idea.  I will link it here when I have the idea up and I know that Esri has linked it to the enhancement request.  We'll want to "tell all our friends" about it once it goes up.
I hope this helps.
Mitchell Grafstein, Horticultural Inspector 1, NYS Dept. of Agriculture and Markets
MitchellGrafstein
Put up a new idea for this.  It should be linked to an enhancement request that I am working on with Esri Technical Support.  Please kudos the idea to add support: https://community.esri.com/t5/arcgis-online-ideas/support-sync-for-field-types-esrifieldtypetimeonly...
