New App Update: I Now Receive Calculation Errors from Arcade Expressions.
1414
01-12-2024 06:33 AM
ArmstKP
UPDATE:  Issue was our ArcGIS Server.
I have a layer in the map that is an ArcGIS Server secured service through an ArcGIS Online item.  The expression uses that layer to run calculations, through an intersects function.  This has been working great, up until the new update to the Field Maps app.  Anybody running into the same?
ArmstKP
@Chris I just retested it and it now works.  It didn't work last evening for a number of hours after I updated the app, maybe it had something to do with accessing our ArcGIS Server.  Ok, nothing to see here...... 😁
ChrisDunn1
Hi @ArmstKP - can you share the arcade you are using so we can take a look?
ArmstKP
