Multi-point editing by search
496
05-12-2024 03:11 PM
JoaquinCasanova
In FieldMaps, is it possible to select multiple points and edit them simultaneously, eg, change the same field on all selected points?
If so, can this be done via search? Let's say there's a "Zone" field. I would search for all points with a given zone, then select all the results, and modify another field, for instance, "SamplingDate" for all of them, leaving other fields unchanged.
Thanks!
