Layer Not Rendering in Field Maps Mobile App, Despite Appearing in Designer and Map Viewer
893
05-27-2025 09:13 AM
MieszkoFydrych
I'm experiencing an issue with one of the layers in a Field Map. The map contains several layers, all of which are functioning normally—except one. This particular layer:
  • Renders correctly in Field Maps Designer and in Map Viewer
  • Appears in the legend within the Field Maps mobile app.
  • Allows users to collect new features successfully in the field.
However, the problem is that this layer does not render visually on the map screen in the mobile app—existing features are simply not displayed.
Has anyone encountered a similar issue or have any suggestions for what might be causing this? Any help would be appreciated.
L77
I had a new  issue recently where the symbology in field maps didn't match how I configured it in the field maps designer and in the map viewer.
I had to go into the feature service for the individual layer and click on the visualization tab, and then configure the symbology there and then field maps shows the symbology correctly.
Also check to see if you have any filters turned on in field maps on the layer.
