IOS login errors for field maps
1642
06-10-2024 09:34 AM
gabrielriley
We have an issue with logging into field maps app through our IOS devices for our enterprise environment.
We cannot log into our portal environment through field maps (just started today) on our IOS devices, however we can login, in field maps on anything running Android.
I'm wondering if anyone has had this issue happen to them and how to fix it.
Here is what we are working with.
Currenlt setup:
Portal 10.9.1 (federated)
Field Maps Verion: 24.1.1
IOS Verion: 17.5.1
Any help or advice would be greatly appreciated thank you.
DanielFox1
Hi @gabrielriley
Not sure if this has been resolved but is your Enterprise public facing?
You may need to configure a proxy or firewall to allow the connection to call back and forth from your device to portal.
Please also see the following technical article on this error message you are getting
https://support.esri.com/en-us/knowledge-base/error-arcgis-field-maps-the-server-may-not-be-respondi....
