I'm getting this error (Esri.ArcGISRuntime.ArcGISRuntimeException: SQLite constraint violation: SQLite: 19
Abort due to constraint violation) using an offline map; and this error "Unable to Submit 1 or more attributes failed" using the same map online. I'm using a Trimble R2 GNSS and Esri Field Maps to collect.
Here was my general workflow:
I get the same errors when I switch back to Geoid 18. I can use my phone's GPS to collect points and autofill GPS metadata fields, but as soon as I switch to using Trimble R2, I get the errors again. I believe I can collect points using R2 and a point feature that does not have GPS metadata fields. I need to test further.
Any suggestions?
Solved! Go to Solution.
Problem Solved! It was indeed the name of the receiver that was causing the original errors. I made a new feature and added GNSS metadata as I usually do. Then I deleted the column for the receiver name, shared to web layer, added to my map, and was able to collect data again. Weird! So then I shortened the name of the receiver in the R2 settings to 2 letters and it worked. The default name was something like 20 asterisks (i.e. "******************************************"). I still don't understand why I was able to collect data including the name of the receiver before changing the Geoid. But for now I am back in business.
Thanks for the tips. I hope this helps others moving forward.
If you are not on the newest version of the app I would try and update the app. In relation to the unable submit error you get please see this community post
Unable to submit error - 1 or more attributes failed.
This mentions collector but the solution should hopefully work for you also.
Have you had any schema changes before trying to submit changes?
Thanks for the suggestion, @DanielFox1.
I did ensure I am using the latest app version. It is up-to-date. Always a good reminder.
I also reviewed the link you sent. I didn't write any script, so I don't think that is the problem. But similar to @EvoAndreatti and @JosephGrossman , I am using an R2. I have also enabled GNSS metadata attributes. But, unlike @JosephGrossman , I do not think it is the name of the receiver that is the problem because I have been using the same receiver with GNSS attributes enabled for a while now. For me, the problem started when I changed the geoid settings in Trimble Mobile Manager.
Any other suggestions?
