FieldMaps bug after update - Android
1023
05-21-2025 12:42 AM
JosefineAxelsson
I've noticed that only the first part of "Display Name" is visible in FieldMaps on Androids, only about 50 characters. The full texts have been visible in the past and still seem to work on iPhones.
This is quite a big problem because we have a large number of layers of questions/field names that are longer than 50 characters.
Is this a known bug? And does anyone have a solution to this?
KerriRasmussen
Hi @JosefineAxelsson. The behavior you are seeing on Android is a design limitation of the software. For fields where you have over 50 characters, you may want to consider using the description field which has a 255 character limit to supplement the question/display name. You could also use an Info or TextElement field above the field to provide additional details.
