Field Maps
554
10-26-2024 11:41 AM
UHU
Hi, I have some questions according the work with the field maps app
1. Is it possible to reorder the fields in the layer filter list. I was able to reorder the fields in the popup and in the edit section of the feature. I did that with field map designer but I was not able to reorder the fields in the map viewer, it is possible in the map viewer classic. So if I select the filter of the layer in Field Maps it shows up my originally created fields as a list to choose but I did not find any possibility to reorder that list, so that it is the same as my configured popup list.
2. Is there a possibility to see the sum of the features after running the layer filter or is it possible to select all or some of the  displayed features to see how many they are?
3. Is there a possibilkity to create curves?
Thanks in advance for any hint.
Beste Regards
Uli
