Solved! Go to Solution.
You will want to click the "Organization" tab on the top and then a "Settings" tab will show under that, as long as you are an Admin for the organization. Then look for the "Map and Scene" settings on the next page and the defaults I mentioned above. If you dont have access to this page, you should ask the organization admin to help you verify this.
Hi @GeorgeJonesRIGOV ,
Are you working in ArcGIS Online or Enterprise? The Esri basemaps should be available by default in AGOL and some extra steps are needed for Offline basemaps in Enterprise. Has your organization made any changes to the default basemap or the basemap gallery? If you have a screenshot or an error when you try to access these basemaps that would be helpful. Do they work fine in Map Viewer?
Are you an admin for your organization? You can verify if any changes were made in the organization settings. Go to the Settings tab and select "Map and scene". Are you using Esri default for the basemap and group gallery?
