Double data type field changes the the recorded value to different value
936
02-19-2024 02:55 PM
DianaValadares
I created a hosted feature class to capture weather conditions and added double data type fields to store decimal values for Temperature measurements and Wind. The double fields change the value from what has been recorded to a different decimal value (usually below the typed value).
The error happens without a clear pattern. Sometimes in the temperature measurements, sometimes in the wind speed. Is there a fix for this issue?
Example: The Wind Speed was typed as 9.34 (km/h) and it was recorded as 9.300000000000001.
