Created datasets in ArcPro and shared to Field Maps but data in Field Maps isnt syncing to ArcPro
1128
11-11-2024 01:37 PM
briganttine
So, after I created feature datasets and feature classes within ArcPro, I then published my data as a web layer. Followed video: https://youtu.be/lnFKt5pM_Lk?si=9ZvegRJjepaMUZNV to show you all of what I did.
I can't remember how to sync the field data back to my ArcPro map. I have also gone into my web map layer on AGOL and opened ArcPro that way but once again it's a duplicate of what I already have.
Thanks for the help!
This video shows a simple way of setting up ArcGIS Field Maps from ArcGIS Pro. It is only using points, but will walk you through going from the desktop software to the online platform, on to the phone, then back through the same pipeline.
ToddW_stl
@briganttine - are you working offline in Field Maps?  If not, make sure:
  • your Field Maps device is connected to data/internet
  • you were logged on to ArcGIS Online within ArcGIS Pro when you published the feature service
  • you're logged in to the same ArcGIS Online account on Field Maps that you were logged into in ArcGIS Pro during publishing
  • you are looking at the correct web map in Field Maps that you added data to in ArcGIS Pro
I don't think you need to do anything to sync data from Field Maps to ArcGIS Pro, as both should be pointing to the live data source/feature service.  You could try clicking the map refresh button in the lower right corner of the ArcGIS Pro map as well.
Debert
Did you navigate to the Hosted Feature Layer in your AGOL and enabled editing sync within settings?
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
