Create templates from configured Field Maps forms
9317
17
06-13-2023 03:10 AM
RebeccaHavard
Hi ESRI Community,
When using Field Maps, I need to be able to create and export a template of my configured Field Maps forms for multiple layers in a hosted Feature Layer to apply to each new project.
We create a Field Maps app for each field project we undertake. At the moment, I can duplicate the Feature Layer our field team needs to use to collect data and create a project-specific web map but when I move to Field Maps designer I have to rebuild the form for every layer every time. This is a time-consuming and repetitive task. It would be really beneficial to be able to export a template of the configures 'master' form and apply it to each new project.
Many thanks,
Rebecca
MarkBockenhauer
With the February 2025 release of ArcGIS Online, when you add a new item—Feature Layer that is based on an existing feature layer, the layer definition (symbols, labels, forms, etc.) will be included in the new feature layer. You will have the entire schema of the source feature layer including layer definition with no features in the new layer.
SBBG_Sel
If I create a new layer from an existing layer will it be independent of the source layer? For example, if the source layer is removed from ArcGIS online will the copied layer work without it?
SBBG_Sel
When I tried creating a new feature layer from an existing layer, the forms did not copy over. Any suggestions?
MarkBockenhauer
Unfortunately, the fix for this had to be rolled out due to other complications. The form information is not being copied over at this time. Hopefully this will be straightened out for the next release.
Using ArcGIS Assistant   you can edit the layer's json and manually copy the forminfo from the source layer to the new layer.
MarkBockenhauer
Update:   This is working in the latest online release.  Using the steps above, you can use any feature layer as a template for a new feature layer, retaining the layer definition (popup, forms, symbols, and more) in the newly created feature layer.
Also, with Field Maps Designer you can create a map template from an existing map.
Then create a new map using the template.
katemcc918
Any sense of when this might make it to ArcGIS Enterprise? I'd really love to make use of this feature.
HeatherMcCracken
Hi @katemcc918
The ability to create a new map from a template was introduced with Enterprise 11.5 (Enterprise 11.5 help).  Enterprise 12.0 further built on this aspect - by enabling you to create your own map templates from existing maps to streamline future projects. (Enterprise 12 help).
It's a great feature! Hope it provides some great efficiencies for you. We are always interested to hear about your experiences and feedback.
Best,
Heather
katemcc918
Awesome, thanks! I think my organization might be a little behind on their Enterprise version so I'll definitely keep an eye out for this feature when they next update.
