Crash on Android while creating a location profile
912
09-17-2024 10:19 PM
Y_Chau
I have seen this on several devices and several versions of Android. This is what happens, while creating a location profile asa I reach the step to choose the area on the world map there is a high probability of Field Maps crashing. It can happen on any step after this, like choosing the transformation or naming the location profile. Workaround I found is to do it very quickly. If I am able to give it a name and save it and if FM still crashes, I can find the newly created location profile on restarting FM. If it crashes before I could save, then I have to create it again. Would be nice if this could be fixed.
Thanks
ColinLawrence
Hi @Y_Chau , are you seeing this issue when creating a specific profile with the same inputs or can your reproduce it using different inputs when creating the Profile? Can you provide an example Profile where you are experiencing crashing? Also, let me know the device you are using and the OS version.
Regards,
Colin
