Calculate field based on filtered points layer
691
02-10-2025 09:10 AM
RileyScanlan
Hi there,
I am trying to pull a text field from a points layer that meets two filter criteria. I have a very similar calculation that works in another field but can't get this to work. I think it's something related to trying to pull one value from a whole featureset? But not sure what the solution is.
Thanks in advance!
// set the point feature layer as a variable
var tree = FeatureSetById($map, "18d5b66cd4a-layer-17")
var filter_by_grid = "'" + $feature["GRID_ID"] + "'"
var filter_by_year = "'" + $feature.PROJECT_YEAR + "'"
// the filter expression
var filter_expression_grid = "GRID_ID = " + filter_by_grid
var filter_expression_year = "PROJECT = " + filter_by_year
// filter the the points to only this block
var filtered_grid = filter(tree, filter_expression_grid)
var filtered_year = filter(filtered_grid, filter_expression_year)
//var trees = First(filtered_year)
return trees.Re_Entry
KerriRasmussen
Hi @RileyScanlan
Good afternoon. Can you tell me more about your workflow? What is the end goal?
