Bug with edit Form Titles
765
04-20-2022 10:18 AM
Trippetoe
Hello.
It looks like i found a bug in the Field Maps Form Title. My form title includes a field from the map layer. If that field is also one of the fields in the form itself, the title displays as expected. However, if the field is not displayed on the form, then the field value doesn't show up in the title.
Here's the specific use case:
  • in the map layer there is a field named 'CaseNumber'.
  • I set the title to "All Cases: {CaseNumber}"
  • If {CaseNumber} is one of the fields displayed on the form, when I edit a feature in Field Maps (or web map viewer), the edit form title is, for example, 'All Cases: 12-3456'
  • If {CaseNumber} is not one of the fields displayed on the form, when I edit a feature in Field Maps (or web map viewer), the edit form title is 'All Cases: {CaseNumber}'
I am using Field Maps version 22.1.0 build 690 on an iPad Pro running iOS 15.1
Tags (3)
