Arcade expression to auto populate attributes and include the indoors floor picker on polygon selection
1141
08-15-2025 09:17 AM
schulte_a
I have ArcIndoors and all my floor data (using the Indoors schema). I want to spin up web maps using smart forms, to where when a person places say a point in the Fire Extinguisher layer, it will auto populate in the extinguisher attributes for the LEVEL_ID, Building Number/Name, Room Number, grabbing said attributes from the Facilities/Levels/Units Indoor layers. This is the Arcade expression I used, but it seemingly isn't taking into account the floor picker. Any suggestions?
function getContainingID(Levels, LEVEL_ID) {
var fs = FeatureSetByName($map, Levels, [LEVEL_ID, "SHAPE@"]);
   var hit = First(
   Intersects(fs, Geometry($feature))
   return IIF(
   IsEmpty(hit),
   null,
   hit[LEVEL_ID]
czahn2
My team is struggling with the same issue right now. We have found this page of documentation for the Experience Builder Floor Filter Widget: Floor Filter widget—ArcGIS Experience Builder | Documentation
If you scroll down to near the bottom there is an Arcade script:
if ($editcontext.editType == "INSERT") {
var levelsLayer = FeatureSetByName($map, "Levels", ["*"], true);
var features = Intersects(levelsLayer,$feature);
if (Count(features) > 0) {
var levelId = First(features)["LEVEL_ID"]; return levelId;
} return $feature["LEVEL_ID"];
We have had inconsistent luck with getting this to function correctly. It sometimes errors out with 'Failed to calculate value'. But worth a shot.
For Field Maps the Arcade is a little different due to how Experience Builder and Field Maps natively support Indoors. We got a script from the Field Maps Team for Unit ID, which could potentially be modified to populate Level ID:
if(IsEmpty(Geometry($feature)))
    return null
else if (IsEmpty($feature.LEVEL_ID)){
    return null
else {
    var filt_floor = $feature.LEVEL_ID
    var result = First(Intersects($feature,Filter(FeatureSetByName($map, 'Units'),'LEVEL_ID = @filt_floor')));
    if(IsEmpty(result))
        return null
    else {
        return result.UNIT_ID;
