ArcGIS Field Maps 25.2 patch releases
10617
24
10-08-2025 09:21 PM
JeffShaner
13 24 10.6K
ArcGIS Field Maps Patch Releases
This article will provide updates on specific patch releases by platform, with resolved issues reported through Esri support. It also includes active patch development efforts with the Field Maps and Maps SDK teams.
Latest Patch Release
Android (25.2.7)
  • BUG-000179946 - In ArcGIS Field Maps 25.2.x, the last edit summary does not display even though it is included in the pop-up configuration of the web map.
  • BUG-000180124 - GPS metadata is missing from the pictures uploaded as attachments in ArcGIS Field Maps 25.2.x on Android 14.
  • BUG-000180053 Identify: Performance when expressions are present in popup is significantly worse than 25.1.
  • BUG-000179903 Nearmap US Vertical Imagery layer fails to load in ArcGIS Field Maps version 25.2 with error "Invalid JSON start: < : 0.
  • BUG-000179924 - Attempting to edit a feature with related records in some web maps returns: "Unable to Submit 'The operation couldn't be completed. (ArcGIS.ArcGISError error 1.)'" error in ArcGIS Field Maps version 25.2.0.
  • BUG-000180124 - Attachments: Choose File - Location data in EXIF lost after resizing photos.
  • Collect: Getting "Unable to attach. Check your Wi-Fi or cellular connection" error when trying to attach or take photo on EXISTING Feature if Service URL has http not https.
iOS (25.2.5)
  • BUG-000180053 - In ArcGIS Field Maps 25.2.0, loading pop-ups that use expressions is slow when identifying or editing a set of features.
  • BUG-000179971 - After updating to ArcGIS Field Maps 25.2.0 on iOS devices, excessive battery drain with routine workflows.
  • BUG-000180195 - GPS metadata is missing from pictures with HEIC or HEIF format uploaded as attachments in ArcGIS Field Maps 25.2.x on iOS v26.0.1.
  • BUG-000179875 - Logging into ArcGIS Field Maps 25.2 using SAML or OIDC fails and returns the error message "Certificate Required" when In-App OAuth Handling is enabled.
  • BUG-000175907 - Pop-ups do not load in the ArcGIS Field Maps mobile app after publishing the WaterDevice UN feature class from a file geodatabase or traditional version enterprise geodatabase as a referenced layer with select field visibility disabled.
  • BUG-000179846 - Unable to login through an Enterprise Portal in ArcGIS Field Maps 25.2.0 with "Sign In Error: Unknown error occurred" if a URL of portal helperServices is an empty string ("analysis": {"url": ""}) or contain a leading space.
Previous Patch Releases
Released 10/20
  • Android 25.2.6
    • BUG-000176361- The $originalFeature function fails during feature creation in ArcGIS Field Maps version 25.1.0, while editing existing features is successful.
    • BUG-000179995 - Logging in to certain Enterprise Portals in ArcGIS Field Maps 25.2 fails with 400 Invalid redirect_url with redirect authentication method and with certificate error using in-app method.
Released 10/14
  • iOS 25.2.4
    • BUG-000179961 - The Edit option is not available for features containing true curves in ArcGIS Field Maps 25.2.0.
    • Trimble: Integrated Receiver removed as location provider option after successful Trimble migration
    • BUG-000179914 - The ArcGIS Field Maps mobile app v. 25.2 is generating error "Basemap Unavailable The spatial reference isn't compatible with this map." when trying to switch to a sideloaded .tpk basemap with the same spatial reference as the current map.
    • BUG-000180044 - Logging into ArcGIS Field Maps 25.2.0 fails if the app configuration in Mobile Device Management (MDM) has no location profile set with the error "Invalid MDM configuration one or more location profiles are invalid".
  • Android 25.2.5
    • BUG-000179925 - Android users are unable to access existing offline map areas after upgrading to ArcGIS Field Maps version 25.2.
    • BUG-000180005 - ArcGIS Field Maps 25.2.2 on Android fails to load the form or template for specific feature layer hosted on Enterprise Portal with error "Unable to display The form can't be displayed. Contact the map author for more information" or "The form contains unsupported data"
Released 10/13
  • iOS 25.2.3
  • Android 25.2.4
    • BUG-000179866 - When editing a feature layer in the new version of ArcGIS Field Maps (25.2) the options Take Photo or Attach return an error: "Unable to Attach: Check your Wifi or cellular connection" on the mobile application user when the Services REST Directory is disabled.
    • BUG-000179998 - Android users are unable to log in to certain ArcGIS Enterprise 10.9.1 organizations configured with SAML after upgrading to ArcGIS Field Maps 25.2.
Released 10/8
  • iOS 25.2.2
    • BUG-000179817 - Search by layer in ArcGIS Field Maps 25.2 does not return search results when a group layer from a map service is used as the search source in the web map settings.
  • Android 25.2.3
Released 10/6
  • iOS 25.2.1
    • BUG-000179854 - The $originalFeature function fails during feature creation while editing of existing features is successful.
  • Android 25.2.2
    • BUG-000179910 - ArcGIS Field Maps mobile app 'Take photo' functionality displays a black screen on Android devices when using In-app camera (recommended option) in both recent updates v25.2 and v25.2.1.
Active Patch Development issues:
  • BUG-000179885 - In ArcGIS Field Maps 25.2.0, it is no longer possible to switch to a basemap that uses a different spatial reference than the web map.
NOTE: This list of issues and patches can and will change. Please refer back to this post frequently if you are affected by a regression from the 25.2.0 release.
24 Comments
GISMike
BUG-000176361 - is a huge problem. I've got several clients with Android devices that cannot collect any data, because the calculated expression fails when collecting a new point. Please fix this issue ASAP!
Thanks, Mike
ChrisDunn1
Hi @GISMike ,
The fix for that bug just went out on Android today. Please verify that you have version 25.2.4 installed and let us know if you are still seeing the issue.
Chris
GISMike
Thanks for the prompt reply!
Yes, I tested it earlier today with version 25.2.4, after I had several phone calls from different clients. It did not fix the problem. We confirmed it works fine on iOS, but not Android. Feel free to email me to follow up in detail.  [email protected]
Thanks!
ChrisDunn1
Hi @GISMike ,
My apologies - that bug was erroneously marked as fixed on Android and you are correct, it has not been fixed yet. I'll send you a follow-up e-mail with more details.
Chris
JeremyUmlauf
Currently our biggest issues are that users are experiencing  being logged out multiple times throughout the day and having to log back in, but a huge one is we have a filter set on a point layer and in enterprise 11.4 the filter works as it should but when you go to the field maps app and open the map the points that should be filtered out are not? If there is somewhere I should be reporting this other than here please let me know.
Jeremy
ChrisDunn1
Hi @JeremyUmlauf ,
In general the best course of action is to report these problems to support (support.esri.com) via your GIS administrator. That being said, we can still do some triaging or offer assistance.
Are the repeated sign-in prompts also on Enterprise 11.4? What sort of authentication method do you use? Are you seeing the issue on iOS and Android or just one platform?
For the filter, what is the filter expression that is being applied?
Feel free to respond here or reach out with more details via [email protected]
Chris
StevenKincaid
Our organization is still having issues with the trusted certificate error for ArcGIS Server services on iOS devices running Field Maps version 25.2 and highter.  I just tested 25.2.4 and same thing.
RoseSmith_Sageland
My organization uses field maps for photo-point monitoring. With the new update, I am no longer seeing the option to rename attachments or delete attachments. Both functions are pretty vital to our file organization and field methods. Have these functions moved and I am just not seeing them in the app. Looks like my device is running 25.2.2.
ChrisDunn1
Hi @RoseSmith_Sageland,
Which platform are you using? In either case, you should be able to long-press on an attachment and see a menu with options to re-name or delete the attachment. Note this is only when you are capturing or editing a feature.
Additionally, on Android when you are previewing an attachment you can use the overflow menu in the top-right corner to rename or remove the attachment as well.
I hope that helps - please let me know if you do not see those options.
Chris
MiaogengZhang
@StevenKincaid can you send me direct message with troubleshootlong (Click skip sign in and at Profile page)? Also you can share portal URL.
StevenKincaid
@MiaogengZhang Sent you a direct message.  I also have an active open Esri Case#.  Thanks
ToddCopeland
An escalated case has been created for the issues listed below.
We are receiving a Service Error Code 400. Unable to move geometry and update attribute information using Field Maps versions 25.2.x.
Users are no longer able to create new geometric network features, update geometric network features, and update any geometric network feature attribute information via ArcGIS Field Maps with version 25.2.x. Users are able to complete tasks as expected with non-geometric network related features.
The Portal URL has been removed from application, forcing users to enter the Portal URL and log back into the Enterprise. Users also are no longer able to use the camera to read barcodes or QR codes and capture the data to populate the fields as configured in the Web Maps.
We have had a couple of users lose their Trimble receiver connection information as well. Hoping the new update will address this issue.
We have an iPad using 25.1 and this version is able to complete all tasks as expected without any errors or issues.
MaxMolello
Just wanted to see if there were any updates on a few bugs. Map load time and pop-up performance are still abysmal in the latest Android version and my hundreds of users are getting pretty frustrated and angry. Also the Android login loops after SAML sign in. I'm really not enjoying taking the heat for something I have no control over and worked just fine for years. We're even considering spending a lot of money to go back to georeferenced PDFs at this point.
NateHollenbeck
I’m experiencing issues with an iOS device after updating to version 25.2.x. The data is displaying with incorrect symbology, and the pop-up information is not visible within Field Maps. The view layer works correctly in ArcGIS Online and in an earlier version of Field Maps (25.1.0). Any guidance on how to resolve this issue would be greatly appreciated.
JorgeBertin_Corvalan
Hi, With version Android  25.2.6, we are unable to attach photos when updating a record. The error "Could not attach" appears, "Check your Wi-Fi or mobile data connection."
, error.pngerror.pngWe cannot attach photos with version Andorid 25.2.6, it says there is a data or wifi error.
ChrisDunn1
Hi @JorgeBertin_Corvalan ,
We have seen this issue and are currently working on a fix for it. It is likely caused by a service in your map using http instead of https, I believe it's more common in older maps that may have been around for a while. If you re-save the map it should update the urls to use https and resolve the issue.
I hope that helps!
Chris
Thanks for your reply, @ChrisDunn1 . It's hosted on AGOL. I assume the hosted services are at https://essal.maps.arcgis.com/home/item.html?id=206698a9b5444456bae1XXXXX....
IntelliVietnam
Hi, I've got several clients with Android devices that cannot zoom to feature after search. Please help to check and fix this issue ASAP. Android 12, Fieldmaps 25.2.7 - 2516
BenK2
Similar to other comments, we also are experiencing issues with search results not being zoomed to/highlighted/selected properly on IOS. This seems to happen when the map is beyond the visibility range of the respective search layer. This is disrupting workflows, when will this be fixed?
ChrisDunn1
Hi @IntelliVietnam , @BenK2 , and anyone else having issues with panning and zooming to a feature from a search result.
I have not been able to reproduce any issues in my testing, however there is a small behavior change in the newer release of Field Maps that may be throwing you off. Previously, when tapping on a search result from the list of results, the app would pan and zoom to the feature or placemark. Now, the app will only pan. If you would like to zoom in as well as pan, tap on the swatch showing the feature symbol, instead of just the row with the feature name. Tapping on the swatch next to the popup title will work as well to zoom in.
If you are experiencing an issue where tapping on the row or the swatch is not resulting in the map view panning or zooming, please reach out to [email protected] with more details, or consider opening a case with support so we can investigate further.
Chris
MaxMolello
@ChrisDunn1 I can confirm this works. However, I'm really not a fan of this change. Why would you even not want to zoom to the feature you just searched for? I can see this being really confusing to users since they now have to remember to tap in the correct place of a search result, this is not what a user would expect to happen. Also, why was this not communicated anywhere else along with all other changes likes this?
I have also gotten complaints from users on the new swatch color, it used to just be flat black (in dark mode) same as the background, this made the symbol really stand out. Now the mid-grey circle really clashes with any symbol color I've seen on it, making it harder to identify the symbol.
BenK2
@ChrisDunn1 Noted on the tap of the symbol to zoom, but I agree with @MaxMolello that this change is confusing for users and non-intuitive. Why change this at all? We have also had users complain that this confuses them.
Also, I want to call out that tapping on the symbol next to the search result, or clicking on the search result itself, does not highlight the feature on the map. This is with Utility Network data in subtype group layers, on the most recent version of Field Maps on IOS.
KarenHall
On the last two Field Maps updates, when the app was updated on our field crews' phones they were all logged out. We are using the SAML option with authentication through Entra ID. It's been incredibly frustrating as many of our field employees struggle with remembering passwords and managing MFA for access.
Is there anyway to enforce a rule that when the app updates, our users are not logged out?
AndresEcheverri
We are now with Field Maps version 25.2.7. Still the performance for displaying layers is very slow compared to older versions (before the last month updates). Creating offline areas is now causing more issues (nothing evident in the logs that is causing the failure, more time to download offline areas and I guess timeouts), also we experienced the true curve sync issue that I'm glad is not longer there. Some offline areas are also not preserving configurations, for example we set the transparency in a layer and you can see in the online Field Map the layer is transparent, once an offline area is taken, the layer goes to solid which it is annoying for users that now have to turn off/turn on the layer all the time. We use Field Maps with ArcGIS Enterprise 11.2.
Contributors
About the Author
I am the Group Product Engineering Lead for our Field Apps team at Esri. I work with an amazing team building out our field solutions. Please feel free to ask me anything about ArcGIS Field Maps, Workforce, and Navigator.
