ArcGIS Field Maps 25.2 patch releases
10621
24
10-08-2025 09:21 PM
JeffShaner
13 24 10.6K
ArcGIS Field Maps Patch Releases
This article will provide updates on specific patch releases by platform, with resolved issues reported through Esri support. It also includes active patch development efforts with the Field Maps and Maps SDK teams.
Latest Patch Release
Android (25.2.7)
  • BUG-000179946 - In ArcGIS Field Maps 25.2.x, the last edit summary does not display even though it is included in the pop-up configuration of the web map.
  • BUG-000180124 - GPS metadata is missing from the pictures uploaded as attachments in ArcGIS Field Maps 25.2.x on Android 14.
  • BUG-000180053 Identify: Performance when expressions are present in popup is significantly worse than 25.1.
  • BUG-000179903 Nearmap US Vertical Imagery layer fails to load in ArcGIS Field Maps version 25.2 with error "Invalid JSON start: < : 0.
  • BUG-000179924 - Attempting to edit a feature with related records in some web maps returns: "Unable to Submit 'The operation couldn't be completed. (ArcGIS.ArcGISError error 1.)'" error in ArcGIS Field Maps version 25.2.0.
  • BUG-000180124 - Attachments: Choose File - Location data in EXIF lost after resizing photos.
  • Collect: Getting "Unable to attach. Check your Wi-Fi or cellular connection" error when trying to attach or take photo on EXISTING Feature if Service URL has http not https.
iOS (25.2.5)
  • BUG-000180053 - In ArcGIS Field Maps 25.2.0, loading pop-ups that use expressions is slow when identifying or editing a set of features.
  • BUG-000179971 - After updating to ArcGIS Field Maps 25.2.0 on iOS devices, excessive battery drain with routine workflows.
  • BUG-000180195 - GPS metadata is missing from pictures with HEIC or HEIF format uploaded as attachments in ArcGIS Field Maps 25.2.x on iOS v26.0.1.
  • BUG-000179875 - Logging into ArcGIS Field Maps 25.2 using SAML or OIDC fails and returns the error message "Certificate Required" when In-App OAuth Handling is enabled.
  • BUG-000175907 - Pop-ups do not load in the ArcGIS Field Maps mobile app after publishing the WaterDevice UN feature class from a file geodatabase or traditional version enterprise geodatabase as a referenced layer with select field visibility disabled.
  • BUG-000179846 - Unable to login through an Enterprise Portal in ArcGIS Field Maps 25.2.0 with "Sign In Error: Unknown error occurred" if a URL of portal helperServices is an empty string ("analysis": {"url": ""}) or contain a leading space.
Previous Patch Releases
Released 10/20
  • Android 25.2.6
    • BUG-000176361- The $originalFeature function fails during feature creation in ArcGIS Field Maps version 25.1.0, while editing existing features is successful.
    • BUG-000179995 - Logging in to certain Enterprise Portals in ArcGIS Field Maps 25.2 fails with 400 Invalid redirect_url with redirect authentication method and with certificate error using in-app method.
Released 10/14
  • iOS 25.2.4
    • BUG-000179961 - The Edit option is not available for features containing true curves in ArcGIS Field Maps 25.2.0.
    • Trimble: Integrated Receiver removed as location provider option after successful Trimble migration
    • BUG-000179914 - The ArcGIS Field Maps mobile app v. 25.2 is generating error "Basemap Unavailable The spatial reference isn't compatible with this map." when trying to switch to a sideloaded .tpk basemap with the same spatial reference as the current map.
    • BUG-000180044 - Logging into ArcGIS Field Maps 25.2.0 fails if the app configuration in Mobile Device Management (MDM) has no location profile set with the error "Invalid MDM configuration one or more location profiles are invalid".
  • Android 25.2.5
    • BUG-000179925 - Android users are unable to access existing offline map areas after upgrading to ArcGIS Field Maps version 25.2.
    • BUG-000180005 - ArcGIS Field Maps 25.2.2 on Android fails to load the form or template for specific feature layer hosted on Enterprise Portal with error "Unable to display The form can't be displayed. Contact the map author for more information" or "The form contains unsupported data"
Released 10/13
  • iOS 25.2.3
  • Android 25.2.4
    • BUG-000179866 - When editing a feature layer in the new version of ArcGIS Field Maps (25.2) the options Take Photo or Attach return an error: "Unable to Attach: Check your Wifi or cellular connection" on the mobile application user when the Services REST Directory is disabled.
    • BUG-000179998 - Android users are unable to log in to certain ArcGIS Enterprise 10.9.1 organizations configured with SAML after upgrading to ArcGIS Field Maps 25.2.
Released 10/8
  • iOS 25.2.2
    • BUG-000179817 - Search by layer in ArcGIS Field Maps 25.2 does not return search results when a group layer from a map service is used as the search source in the web map settings.
  • Android 25.2.3
Released 10/6
  • iOS 25.2.1
    • BUG-000179854 - The $originalFeature function fails during feature creation while editing of existing features is successful.
  • Android 25.2.2
    • BUG-000179910 - ArcGIS Field Maps mobile app 'Take photo' functionality displays a black screen on Android devices when using In-app camera (recommended option) in both recent updates v25.2 and v25.2.1.
Active Patch Development issues:
  • BUG-000179885 - In ArcGIS Field Maps 25.2.0, it is no longer possible to switch to a basemap that uses a different spatial reference than the web map.
NOTE: This list of issues and patches can and will change. Please refer back to this post frequently if you are affected by a regression from the 25.2.0 release.
24 Comments
Contributors
About the Author
I am the Group Product Engineering Lead for our Field Apps team at Esri. I work with an amazing team building out our field solutions. Please feel free to ask me anything about ArcGIS Field Maps, Workforce, and Navigator.
