unable to open mobile map package
8099
14
07-21-2018 06:48 PM
BobChristensen
Hi, I just uploaded a mobile map package, then downloaded to my explorer on an ipad. When the download completed it was labelled as an invalid map and when I tap to open I get this message: "unable to open map the package is required to be unpacked into individual files before use".
I also tried loading the mobile map package using Itunes. I got the same message with that one.
Here is a link to the package. https://ssp-community.maps.arcgis.com/home/item.html?id=bc7959d403824b769d176d7b764c44a1#overview
Please help.
b
MarkBockenhauer
Bob,
Using the TPK is a bit of a workaround.  We do intend to support some raster files, but right now a TPK is the only way for explorer to display raster information.
Is there any way to retain the legend for the raster in the mobile map package?
This is a shortcoming of using the TPK, and in a larger sense there probably should be a way to create a custom legend for a map that is independent from the layers and layer  rendering in the map.   For data like yours some have included a duplicate 'minimal' vector layer with the legend information they want.   I have even seen users add a map extent polygon, symbolized 99% transparent, where feature popup is configured with attachment (PDF file) to provide legend and other information.
 What is the benefit of making these raster layers basemaps vs just regular layers?
In general it is good practice to have basemap in Mobile Map Packages that you create, though it is not required.  In the example I posted I combined the bear habitat with DEM layers which creates a single TPK and saves a bit of space from having 3 separate TPKs.  However, if your intent is to have all of the layers in a single map, then by all means a TPK for each as operational layer is the way to go.  This allows users to turn the layers on and off in Explorer.  Basemap layers are represented as a 'singular background picture' in Explorer and cannot be interacted with.
Do you foresee layer transparency control coming to explorer?
How do you want to use layer transparency in Explorer, or how do you envision your map users using it?
Just in general if you could share a little information on how users are supposed to use your map, or anything that would allow you to communicate with your map more effectively, using Explorer, we would like to hear it.
Mark
BobChristensen
Thanks again Mark,
I would be happy to provide more detail on our planned uses for this data - generally three primary audiences: youth thorough a map heavy place-based curriculum, hunter-gatherers in rural Alaskan villages (hence the blueberry, devils club, salmonberry, hudson bay tea, deer and salmon maps) and land managers (both data acquisition and ground-truthing/environmental monitoring.
Would it be possible to arrange a phone call to consult on how we would use explorer within these scenarios? I would really benefit from a solid orientation so that I can see more clearly how to use Collector with Explorer and AppStudio apps to build out a functional system. Following that orientation, I would be happy to write up our case study and share with others.
b
MarkBockenhauer
Bob
Yes, I will contact to arrange call.
Mark
by Anonymous User
Not applicable
Joel Whitney wrote:
Hey Bob Christensen
They reason you're getting this error is because rasters images are not yet supported in Explorer. As a workaround, you can Create Tile Package's out of the raster images. The resulting TPK's would then display in Explorer as expected.
Hello Joel, I have also had this problem and am attempting to make map tile packages now to see if it will allow me to view imagery.  I am however confused as to why the latest entry in the version history for Explorer on the app store clearly says that raster data can be used offline (see below). It just seems a little disingenuous. It also seems silly that Collector can easily download web maps with cached imagery while explorer requires such a roundabout process to view maps offline - do you happen to know if the ability to download maps from ArcGIS Online within the Explorer app is coming or being worked on?
18.1.1
May 10, 2018
- Imagery and other raster data can be used offline
- Various bug fixes and improvements
MarkBockenhauer
Sam,
Collector as part of the Aurora beta is improving and enhancing the capabilities for taking a map offline.  Once that work is completed we will be putting it into a future version of Explorer.
We will also continue to improve the 'roundabout' process of using ArcGIS Pro to create an offline map.
Mark
