Is Explorer possible to record a track(gpx).
1220
06-10-2019 08:41 PM
KalSsin
Hi~~
The mmpk(map) is good.
Is Explorer possible to follow a track(gpx).
Is Explorer possible to alarm for stray from track.
It would be great if Esri added the above function.
There are only a few people who make maps(mmpk).
There are many people who use maps.
High-priced programs such as navigation are too much for many to use.
I hope many peoples can use a good map(mmpk).
BrentPierce
Kal,
Have you tried the tracker solution?
https://www.esri.com/arcgis-blog/products/tracker/announcements/tracker-for-arcgis-v19-1-0-released/
We explicitly built this app to track your location efficiently.
With respect to following a GPX track I would be very interested in the underlying problem your are trying to solve here. Seems like a really interesting use case can you provide more information.
The next release of Explorer will provide what we call Compass Mode which is a way to use your device to find a specific feature when you are in the field. This is often used to get "as the crow flies" type directions to a feature in your GIS when you are near it in the field.
Hope this helps,
-Brent
KalSsin
Hi    Brent pierce~~~
Thank you for your reply.
I want to use offline map for traveling or hiking.
There are a lot of kinds of applications.
Oruxmaps, locus pro, alpinequest etc.
They have a lot of users.
https://www.oruxmaps.com/cs/en/
https://www.locusmap.eu/
https://www.alpinequest.net/
The problem is that applications cannot use mmpk.
Those applications use mbtilemap or mapsforge map.
Instead of making a lot of apps, I want a good one.
Explorer the most suitable application.
(navigator and tracker aren’t suitable)
We recommend you try oruxmap yourself.
