Explorer on iOS Opens Map with all Layers On
996
01-04-2017 07:28 AM
LucasScharenbroich
I have a web map that, when opened in Explorer for iOS, initially loads the map with all of the layers turned ON.  If I open the Map Layers menu item and toggle *any* layer, then the map refreshes itself into the proper state.
The Web Map uses a Dynamic Map Service (not a Feature Service) and does not override the Map Service's default visibility settings and the Map Service itself has appropriate defaultVisibility properties set on each layer, e.g.
     "defaultVisibility": false,      "subLayerIds": null,      "minScale": 0,      "maxScale": 0
The issue was originally observed on version 10.2.9 of the app.  After upgrading to the most recent version (10.2.10), the problem remains.
Does anyone have a suggestion on how to work around this issue?
Thank you.
