Explorer basemaps
1162
12-17-2019 08:21 AM
MartyHollas
Explorer (IOS) beta does not have an option for basemaps. Will the option to side-load TPK's to use as basemap be coming soon?
**UPDATE** the final release of this corrected the problem and basemaps is now visible to select. Sideloaded TPK's are working.
BrentPierce
In the 19.1.0 beta which we released last week yes we support the side loading of a TPK and their use as a basemap behind offline areas you downloaded onto the device from your webmap. Is this the functionality you are referring to Marty?
MartyHollas
Hi Brent. I am running the latest explorer beta (19.1.0 (2602) ) and am able to view our offline areas that we generated. I do not, however, see the option to select basemaps from the overflow menu when viewing an offline area (or anywhere). The only options I see are Bookmarks, Legend, Measure, Share Map.
I have placed our TPK's in a folder named Basemaps and into the explorer root (just like we do for collector, where this works)
Am i missing something?
