Explorer 20.2.1 : default local tilepackage base map activation not memorized
572
09-10-2020 03:09 AM
EricMailharrancin
Smartphone : Call Cross Trekker X4 Android
ArcGIS Explorer 20.2.1
Mmpk produced with ArcGIS Pro 2.5.1
Usage : mmpk donwloaded from portal to smartphone connected to our portal
Base map with Tile package copied to smartphone with USB
Each time my users start an Explorer session, they must activate the local tilepackage basemap...
Is there a method to set the display of the local base map activated by default ?
Thanks for your help
