Continuous Timeline symbology in Explorer?
1327
12-31-2018 03:27 PM
PaulCone2
I am setting up a solution for reporting landslides in the field.  We have a Survey123 form and a map to look at the data.  The landslide expert asked if there was a way to have older reports drop off the map (i.e. the ones from last season).  I thought about doing a custom filter on CreatedDate but then I stumbled into the Continuous Timeline symbology that is set by default when you pick a date field.  So I set that and then later we noticed the points weren't visible in Explorer anymore.  So I switched it back to Show location only and they reappeared.
Is there any plan to make this symbology work in Explorer soon?  Seems like a simple thing to support the default symbology for each type in a web map.
Paul
