ArcGIS Explorer for iPhone support attachments?
11646
23
10-31-2014 02:02 PM
LaneHowerton
Can anyone tell me if ArcGIS Explorer for iPhone supports attachments from an enterprize Db shared to ArcGIS Online? I can see them from the AGO viewer but not from Explorer.
LaneHowerton
Good question Glenn. I haven't seen anything else on this yet.
glennhazelton
i'm going to open a ticket on this. doesn't seem like we should have to add and symbolized mapservice layers individually.
LaneHowerton
Exactly…thanks.
Lane H.
GIS Coord.
PLWC, Paragould, AR
870-239-7721
by Anonymous User
Not applicable
To all affected by this issue.
While this thread does indicate work flows to get around this issue, a bug has been logged regarding the functionality of added an map service from ArcGIS for Server to a web map in ArcGIS Online and the lack of pop ups in Explorer for iOS. The bug information goes as follows:
NIM102374 : Attachments are disabled when an ArcGIS for Server map service is consumed, and the feature layer URL must be added to an ArcGIS Online web map to use attachments in Explorer for ArcGIS on iOS.
For now, you will need to add the service using the layer URL rather than the map server URL in order for pop ups to be maintained in Explorer for iOS. This issue has been submitted to the development team for Explorer for iOS. For further information on a fix date, you are welcome to open a case with Esri Technical Support and they can attach your case to the bug so you may follow the status of it through your Esri Global account or you have the option to email the development team for Explorer for iOS here: [email protected].
