Adding Sublayer as Featurelayer
2868
10-12-2011 07:23 AM
JörgMoosmeier
Hi all,
I can add a sublayer from a Mapservice as a FeatureService (or as queryservice delivering features) , eg to make a Dashboard. Works really nice and good.
But the sublayer is generalized (via 'maxAllowableOffset') to a degree which makes it nearly impossible to use the sublayer. The resulting polygons are all triangles.
Is there a way to influence the degree of the generalization?
Regards
Joerg
MikeRudden
The answer is no - you cannot control the degree of generalization. However, problems we have seen in the past have typically been data related - would you be able to share the url to the map service so we could investigate further?
Mike
