Using Bing directions with a map in a coordinate system other than Web Mercator
913
11-05-2010 01:34 AM
BabbageOcelot
Hello all,
- is this possible? From what I can tell, the results given by the directions add-in are returned in 3857 and not re-projected to match the underlying map coordinate system. There's an offset.
Is this a known issue, or should it be working?
Ben.
MichaelBranscomb
Esri Frequent Contributor
Ben,
It should be working fine - but I'll take a look.
Cheers
Mike
