Transfer Explorer Point to ArcGIS Server Geoprocessing Service
4960
9
04-29-2010 05:47 AM
MaryEllen_Perko
Hello.  Does anyone know if there is a sample or something available that can show me how to take a point from ArcGIS Explorer and feed it to a geoprocessing service (that ultimately returns features around that point).  Right now the geoprocessing service (model) takes a Feature Set, but that can change if need be.
Mary Ellen
MaryEllen_Perko
Hello.  I don't know if anyone is interested in this, but I stumbled upon my solution looking through the ArcGIS Server forum and thought I'd share.
This had most of the information I needed.  Just needed a little tweaking for .net and Explorer.
http://edndoc.esri.com/arcobjects/9.2/Java/java/server/webservices/soap_api/gp_overview.htm
Mary Ellen
BillHoney
Hi Mary Ellen,
Are you able to share you code?
I'm hoping to code a scenerio exactly as you described
Regards,
Bill
MaryEllen_Perko
Hi Bill,
Sure. I'm a bit rusty, but hopefully this helps.
I've attached the code for the part of my add-in that takes a point clicked on the map display through setting up the input parameter for the geoprocessing service.  My geoprocessing service (model) only has one input parameter and that is a point feature set.  There may be other ways to do this, but this worked for me.
Let me know if you have any questions.
Best,
Mary Ellen
BillHoney
Hi Mary Ellen,
How do you include the declaration of your GeoProcessing Service ? (SDVReturnRoadCharTools)
if (_SDVReturnRoadCharToolsGPS == null)
       _SDVReturnRoadCharToolsGPS = new SDVReturnRoadCharTools.SDVReturnRoadCharTools_GPServer();  //get this if we don�??t already have it
Regards, Bill
MaryEllen_Perko
Hi.  If I understand the question, I use Visual Studio and I just add the Web Reference.  The URL is the wsdl of the geoprocessing web service and I name it SDVReturnRoadCharTools.  For example:
http://<???>/arcgis/services/ncdot_sdvtools/SDVReturnRoadCharTools/GPServer?wsdl
Then, in the code I've got this:
        SDVReturnRoadCharTools.SDVReturnRoadCharTools_GPServer _SDVReturnRoadCharToolsGPS;
Hope that helps.
Best,
Mary Ellen
BillHoney
Yes, thats exactly what I meant - thanks!
I had missed that key step.
Now all I need is to convert my returned feature class (GPFeatureRecordSetLayer) into something that can be added to the map.  Any clues ?
I can't seem to find any documentation on any of this stuff.  Is it just me?
Regards,  Bill
MaryEllen_Perko
Hi.  I can provide you the bits of code that I created to convert the returned features into notes, but if you are using version 10, I think there are other options you may want to explore.  The notes solution can be a bit cumbersome for users.  We're not using 10 yet, so I can't offer anything more.
Anyway, I've attached the code.  Hope it helps.
Mary Ellen
BillHoney
Hi Mary Ellen,
Thank you so much for that,  you�??ve  been enormously helpful.  I now have it working. 🙂
Out of interest, what are the  newer features you are refering to ?
Regards,
Bill
MaryEllen_Perko
Bill,
Glad I could help.  And sorry I was so vague about "newer features."  Someone posted some suggestions to another related question I had last year.  His suggestions included taking advantage of the ability to use layer packages as geoprocessing output in 10.  I haven�??t looked into it at all since we haven't implemented 10 yet, but it may be worth some investigative time.  There may be other options, too.  I don't know...
Anyway, if it helps, here�??s the other thread:   http://forums.arcgis.com/threads/3160-Convert-GPFeatureRecordsetLayer-to-FeatureLayer?p=155871#post1...
Best,
Mary Ellen
