Shapefile problems
2013
09-19-2011 06:19 AM
carlosmarquez
Hi
I'm experiencing an inconsistent problem whilst trying to import shapefiles into ArcGIS Explorer build 1700. The shapefile is built by some custom code from geography data within a SQL Server database.
My problem is that the shape file is not consistently refused.  Sometimes the shape files import, and sometimes not.  I suspect I am doing something wrong in building the shape files, but I'm really struggling to find the problem
Is there any sort of Shape file integrity checker or validation tool? At least some idea of how to proceed.
thanks
Carlos
by Anonymous User
Not applicable
You may check the Shapefile Repair Tool using the links mentioned below:
http://arcscripts.esri.com/details.asp?dbid=13733
http://arcscripts.esri.com/details.asp?dbid=10806
carlosmarquez
Thanks Jitesh.
Managed to find the problem. just another case of PEBKAC
