Select Date
1326
08-26-2010 07:21 PM
papegowda
I am using ArcGIS explorer 1200 SDK. And I am developing a Tool to selected date information from the date (Shapefile and Geodatabase)
I have tried to select the date using (Hash symbol) following syntax, but not succeeded in it.
<Fieldname> = <Value>
Install Date = #2/7/1996#
Can you please let me know how to select the date information?
Pape Gowda
MichaelBranscomb
Esri Frequent Contributor
I suggest taking a look at the ArcGIS Desktop help on SQL syntax for Shapefile/Geodatabase queries: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s500000033000000.htm - this should help you get the syntax right.
Regards
Mike
papegowda
Thanks Mike,
Its working.
Regards,
Pape Gowda.
