Problem adding add-in(reference) file using Explorer Application Configuration
767
01-11-2011 07:10 PM
PiyushDubey
Dear All,
           I have developed one application using C# and i added the add-in file using ArcGIS Explorer Application Configuration. When i double click the application configuration, ArcGIS Explorer application opens without the required add-in an when i click the property of the add-in it shows that it is not referenced but the mean time when i click that add-in file(eaz), the explorer opens with the required add-in. I want to share the application over the net so i want that the required add-in perfectly add using Application Configuration. Kindly let me know in this regards and mistake i am doing.
Piyush
