Pop-Up/Links Problem
1165
06-27-2011 06:28 AM
InmanHartsfield
I just updated my ArcGIS Explorer from the 1500 version to the 1700 version and seem to be having an issue that I never encountered with 1500. Basically, I have a layer with parcel polygons that have pop-up attribute data. When I click on the feature in the map, the attribute information pops up as it should. However, in the attribute information, I have links to various url's. The links also work, but with one problem. When you click on the link, the information pops up behind the Explorer map, so I have to reduce the Explorer map in order to see the information from the link.
Not sure what the problem is, but this never happened in 1500. The information from the link would always pop up on top of the Explorer map. I would appreciate any thoughts or suggestions as I like all the improvements to 1700, but it is not workable to have to reduce Explorer everytime to see the link information. Thanks.
InmanHartsfield
OK, so no thoughts or recommendations so far. Has anyone else experienced this issue? It just seems odd that the link works, but it does not pop up on top of the ArcGIS Explorer, but rather behind it. Would love to hear any thoughts or comments, even if you are not sure how to resolve the issue. Thanks.
AndreiIvanov
Imman, I cannot repro the case. I click url in popup and IE pop ups on top of the AGX. Not really sure what's going on with your setup, did you have a chance to check behavior on other machine?
