OGC web services support in ArcGIS Explorer
3630
05-06-2010 05:17 AM
SeanGrant
Currently the only OGC web service format you can add is KML. Is there the ability (or will there be the ability) to be able to simply go to Add Content and connect to a WFS, WMS...etc?
If there isn't, I guess I can add it to the Ideas site.
Thanks!
by Anonymous User
Not applicable
Hi Sean,
  With the current release, you can connect and add WMS to ArcGIS Explorer. I also agree that adding support for WFS would be a great idea to post!
Andrew
SebastianBrocks
Note that WMS services won't work if Windows is set to a regional settings where a "," is used for the decimal separator instead of a ".", for example the german regional settings.
I reported this here: http://forums.arcgis.com/threads/2664-problems-with-WMS-layers-invalid-bbox-parameter?p=8288
SeanGrant
Thanks for the reply's!
I have added this as an idea to the Ideas site. Thanks for the tip on the region settings too!
-Sean
