NOAA ENC Data Handler extension for ArcGIS
4847
05-26-2011 02:41 PM
YurikoHashimoto
Has anyone tried to view ENC files (S-57, *.000, *.003 navigational marine file format) using the NOAA free ENC data handler extension in the ArcGIS 10 environment? It is designed for 9.x but I was hoping it could still be incorporated into 10.
I have downloaded and installed the program, but I am not provided with the option to import from S-57 to Geodatabase.
I saw on other threads that there is a free ENC data handler extension for Arc from ESRI (as well as the not-so free Nautical Solutions extension), but I can find no link to the former.
Thanks in advance for any thoughts!
Best regards,
Yuriko
DebraFischman
The extension that I found for NOAA ENC data is only for ArcGIS 9.  Any word about an extension for ArcGIS 10?
Thank you in advance for your time and help.
YurikoHashimoto
This is a rather tardy update, but to answer the above post, there is an ESRI S-57 viewer freely available that works in the 10 environment.
GeoffreyGomez
