mxd to map service missing second tables attributes while join multiple tables 10.1
1330
04-23-2013 01:01 PM
ForamParikh
Hello All,
I have one mxd document which contains one polygon table (spacial table), project info(non spacial table),location table (non spacial table), owner (non spacial ), RFP (non spacial ).
In arcgis 10.0 I did join on Location and owner table (unique key owner_id) , then join between project info and rfp (location_id common field) ,then join on project info and location table(location id common field) and join on project info and polygon table (location id is common). when I open project info table I can see all attributes of all tables and when I created map service of that mxd file I can see all attributes.
But now we upgrade from 10 to 10.1 and when I open same mxd file I can see all attributes in project table in arc map but when I publish it as map service I am not able to see all attributes. I am only able to see project info table's attributes not other table's attributes.
Please help, I need to solve it badly.
Foram
MSUDSI
Its almost a year later and I am finding the same problem.
