Move extensions home
2049
7
07-01-2011 02:31 AM
AchilleasDrosos
Good morning from beautiful Greece,
I try to place the buttons of the PreviousNextExtent.eaz add in to the home tab but i cant make it ...
Can someone help...?
AndreiIvanov
Application Configuration Manager->Customization->Tabs->Home
click "New Group" there, name it whatever you like.  Select your new tab, click "Add Custom Control..." and select you add-in.
DarrylDempsey
Happy 4th July Explorer team from a sunny (at the moment) Holland.
I have tried adding the Prev/Next addin a while ago to a new group on the home tab as described by Andriy, but only got one half of the addin (the previous/left arrow part).
Is there a special trick for this addin because it's actually two buttons?
AchilleasDrosos
you must insert it twice! once for every button!
DarrylDempsey
There's only one .eaz file. Do you mean that if Iadd the same file twice, I end up with both buttons?
AchilleasDrosos
yes i mean exactly that...
DarrylDempsey
Well, blow me down with a feather. It actually works. What will they think of next at ESRI?
AndreiIvanov
When you add the add-in in its properties you'd need to select both buttons to add, otherwise it will add only the first one:
[ATTACH=CONFIG]7607[/ATTACH]
