Identify version of File GDB
3086
06-11-2013 12:06 AM
GraceGrace
Hi
May I know how do we identify the version of a file geodatabase?
Thanks 🙂
JoeFlannery
Honored Contributor
Siew:
Open ArcCatalog and navigate to the file geodatabase location. Right-click on the FGDB and choose the Properties... option.  In the attached screenshot, I used ArcGIS 10.1 to look at an older FGDB and can see the version in the Upgrade Status area of the Database Properties.
GraceGrace
Thanks jrflannery, I noticed that for version 10 and version 10.1, the message will be the same. i.e.
This geodatabase matches the ArcGIS release you are currently using.
Thanks 🙂
