How to Outline a Dynamic Shapefile?
6805
10
04-17-2012 05:41 AM
CharlesGant
Hey folks,
I have a shapefile that I have loaded in arcmap of some counties.  After a piece of python script runs, the counties are shaded to represent some data that was input into the python script.  What I would like to be able to do, is outline these counties instead of shading them.  Also, to clarify, I would like to be able to outline the outer extent only.  I know how to outline each county itself, but what I want is ONE outline for the whole region of selected counties.
Attached is an image of what I'm looking at.  I want to be able to outline the whole set of red counties, not just each county.  Thoughts?
[ATTACH=CONFIG]13589[/ATTACH]
JoeFlannery
Honored Contributor
Charles:
In your python script, could you add code to output a "dissolved" new featureclass of your selected counties for an "outline" shape that represents all counties being considered?
CharlesGant
Charles:
Joe,
Reading up on it now.  Thanks for the Idea!  I'll get back to ya!
JoeFlannery
Honored Contributor
Charles:
Please see this Esri Online Help for the Dissolve tool:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000005n000000
If all your counties of interest have a common attribute in an attribute field, you can "dissolve" on the field/attribute and create a new featureclass.
CharlesGant
Charles:
Joe,
So I tried it, and it gave me an error.  Let me elaborate a little more on what I have.  I have a shapefile that is joined to a .csv file.  The field 'ZONEGROUP' is the joined field.  When I open the attribute table of the shapefile after the join, I see the field and it joined correctly (obviously, or the counties would not shade).  The field has one of 5 values that are possible.  The integers 1-4, and 'null'.  Could it be the 'null' that is the issue?  If I try to dissolve on just the 'FID' field, it works fine and joins all the counties into one shape.  Again, if I try it on the 'ZONEGROUP' field, it gives me a general error.
JoeFlannery
Honored Contributor
The dissolve tool may not be recognizing the joined field as a legitimate field to perform the task.  Perform the join to csv and then create a new featureclass and then perform the dissolve on that new featureclass.
CharlesGant
Did it within ArcMap and it worked like a charm!  Now I just gotta figure out the code to export one feature class to a new feature class.
Thanks Again Joe!
JoeFlannery
Honored Contributor
Try the Copy Features (Data Management) tool.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000035000000
import arcpy
from arcpy import env
env.workspace = "C:/data"
arcpy.CopyFeatures_management("InFeature.shp", "C:/output/output.gdb/OutFeature")
CharlesGant
import arcpy
Ok.  Well that scripts works just fine but the joined data is not coming through to the new feature shapefile.  I have the file joined within the arcmap document itself, could that be why?  Do I need to do it with python somehow?
CharlesGant
import arcpy
Well I figured out the syntax to join, but once again, I'm gettin an error.  Below is the error:
WARNING 000970: The join field ZONE in the join table MEGCWAforHAZARDS is not indexed. To improve performance, we recommend that an index be created for the join field in the join table.
Failed to execute (AddJoin)
I'm trying to join a .csv to a .shp.  Is that a problem?  I tried converting the .csv to .dbf, yet I still get the same error.
