High res printing
2798
06-11-2010 09:58 AM
ColeMoon
Does any body know how to print to a high res image in Explorer? I need to save a few PDF images at 300dpi. Any help would be great?
MichaelBranscomb
Esri Frequent Contributor
To get the map as an image you'll need to use ActiveMapDisplay.GetBitmap() which returns a BitMap of the map at the current display resolution (which for most desktops is usually 96dpi). You can use that BitMap image with PDF converters which have APIs such as PDFSharp (http://pdfsharp.com/PDFsharp/). Unfortunately at this time it is not possible to request a map image greater than the screen resolution.
Regards
Mike
