Georeferencing processing time and efficiency (Python script)
1642
11-13-2017 09:04 AM
VictorGay
Hi everybody,
When I georeference a tif or jpg image on ArcMaps by loading the link table with a dozen control points, the transformation takes a second or two.
However, when I run the Python script using WarpFromFile, it takes around 10 minutes. Here is my code:
arcpy.WarpFromFile_management(input.jpg, output.tif, link_table.txt, POLYORDER1, NEAREST)
Is there any reason for that? e.g. I input a jpg and the output is a tif, perhaps this slows down the process.
Any idea on how to improve the efficiency?
Thanks
XanderBakker
Esri Esteemed Contributor
Georeferencing will only apply the control points to the raster and change the visualization. Updating the georeference will only change the worldfile and not the actual raster.
When you warp a raster a new output raster is created. Depending the type of resampling method the time can increase even more.
XanderBakker
VictorGay
I see, so it's the rectification that takes some time by generating a new output raster.
Thanks
