Georeferencing add in does not work
1900
5
07-11-2011 09:35 PM
AchilleasDrosos
Georeferencing add in does not work i tried it a million times and it just does not work...
BrianLeroux
Works for me. You may weant to provide additional info to your issue so someone will be able to properly assist you.
AndreiIvanov
it is part of ArcGIS Explorer 1700. You can try it there. If it still does not work, let me know the details.
AchilleasDrosos
I tried it in 1700 and also in 1500 version. I am very experienced in georeferencing the point i choose are very precised but the map does not go to the correct position ..
AndreiIvanov
Are you saying that add-in works, but it does not georeference image precisely? This add-in uses very simple affine transformation (three matching points) to georeference a raster, therefore it might not fit your needs. If you are searching for precise match, you'd better take a look at ArcMap's georeferencing capability.
AchilleasDrosos
That is exactly what i say Andriy and of course i used arcmap but what can i do with an add i that does not do a precise job?
