Explorer 1200
3986
16
03-09-2010 08:07 AM
BartHound
Will this get changed at some point, to something a bit more standard, naming is getting a bit long now at 4 characters (1200), I would hate to see Explorer 1,000,000.
MelissaJohnson
Downloaded Explorer 1200 and now my ArcMap 9.3.1 & Catalog crash when I try to open them.  I am going to try to repair, just fyi.
Update:  Reinstalled my 9.3.1 update and it seems to have fixed the problem...
BonnPoland
I had the same problem, so I uninstalled 1900. Will ESRI please address this problem?
dcopple
I installed Build 1200 and can no longer load a .csv file without crashing it.  Build 900 was flawless with the same CSV file, what gives.
Also, since I installed, ArcMap now crashes, I think I have to reinstall it.
Anyone have a workaround on the CSV file, or know what's up?
TedCronin
When is AGX going to support 10?  Will this be 1250/1300 that will be supporting ArcGIS 10?
dcopple
Ended up reinstalling build 900, could not get 1200 to work with ArcGIS and Catalog on the same machine.  Hope 1500 works when it is finally release.
by Anonymous User
Not applicable
Hi Ted,
  If you'd like to consume services from ArcGIS Server 10 into ArcGIS Explorer, then you'll have to apply this patch.
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=116&MetaID=1624
Cheers,
Andrew
TedCronin
Cool, thank you Andrew for reminding me, I saw this and only installed on one of my test machines.
