Editing Symbology
897
06-13-2013 10:05 AM
TracyDash
Is there any way to edit symbology using Explorer? I'm looking at 'select symbols' under Explorer help but I see no such tab when I select a layer on the 2500 build.
Please let me know if there is any way at all I can edit or add symbols.
Thanks!
JeremyHatfield1
Select your layer and you should see a new set of tabs at the top for Feature Layer.  Click on the Appearance tab and you'll see the symbols.  Note that certain kinds of layers cannot be changed, such as when you import a layer package or KML.  If all you see under Feature Layer is a Tools tab, then the layer cannot be changed.  If you aren't even seeing the Feature Layer category, then there's something else going on.
