Drawing 3d Polyline - Problem with placement properties
998
12-21-2010 09:14 AM
marinatarajan
Dear friends,
When we try to plot 3d points as note in AGX 900 with placement3d property as absoluteheigh it works fine.
As per the documentation , the same should work for polyline as well.But something strange happens like only the point locations are drawn with z values and the interconnecting line falls all the ground(draped).
Please reply if anyone has the solution for the same
Thanks is advance
Maddie
