Config File NCFG not being applied
2385
05-31-2013 12:37 PM
DavidHaines
In our setup we have a custom configuration file (.NCFG file) on a network drive.  We created a shortcut to this file for users to use a customized AGX.  This is working fine for all but one of our users.
For some reason the shortcut, and even clicking on the file itself will just cause the default AGX to load.  If I go into Configuration Manager on that PC, and preview the configuration file, it will load fine.  It just won't load by clicking on the NCFG file.  I've uninstalled/reinstalled, deleted all the AGX-related folders I can find in Application Data, but no luck.  This PC should be setup with the same security and configuration as all of the other working PC's.
I've created a new shortcut in the format of -
  "C:\Program Files (x86)\Explorer\bin\E3.exe" /AppConfig c:\path\to\appconfig.ncfg
And this works, but why won't clicking on the NCFG file work in the first place?
