Can't Import Layer
3278
5
07-20-2012 06:59 AM
BrandonShowers2
Using the Add content feature, I am unable to add ArcGIS Layers...  Every time I select a layer to add, it give an error and will not import.  This feature works fine with Windows XP, but I can't get it to work in Windows 7.
Any ideas???
ChrisOest
I am having a similar issue. I get the message "Failed to add layer package(s): filename.lyr (Invalid File). I created the layers in ArcMAP 10.1 and I am using ArcGIS Explorer Desktop 1750 (2.0.0.1750).
AlastairFitzmaurice
I have the same issue too, does anyone have a fix yet?
AndreiIvanov
Layer packages from 10.1 should be working with the upcoming release of ArcGIS Explorer 2012.
AlastairFitzmaurice
Will the new version be backward compatible?
I've tried layers from 9.3 and they don't load either.
AlastairFitzmaurice
I've since found that the paths to the layer files were corrupt and after remaking/remapping them they now work fine as 9.3 layer files.
