Bug report for AGX 2500-corrupted nmf when editing multiple text notes
4471
04-07-2015 02:44 PM
NormanDeschamps
Not sure where else to actually submit a bug report for AGX.
This issue relates to the nmf file becoming corrupted after editing the attributes of multiple text notes that are located in a folder.
To reproduce:
1. Open a new map
2. Create a few map text items.
3. Create a folder
4. Move the text items into the folder
5. Select all of the text items. Right click and change one of their attributes such as size or font
AGX changes the attributes but also creates copies of the text items in the root of the content window. If you save that nmf, close AGX, then try to open the nmf, AGX tells you the file is corrupted. You can manually edit the nmf file to remove the spurious text items it created in the root of the content window and the nmf becomes usable again.
Norman
MarkBockenhauer
Norman,
This issue is fixed for the next release of ArcGIS Explorer Desktop...  Until released... don't put map text notes in folders...
Mark
NormanDeschamps
Excellent! Thanks for the quick update Mark. Looking forward to the new release.
Norman
