Mark,When the download becomes live will the Data expansion pack become available to?Thanks
John,The ArcGIS Explorer 2500 SDK remains unchanged. An add-in developed with 1500 will work in 2500.Mark
Stefan,Yes, a 64 bit version is planned, it currently lags a bit behind the 32 bit version, as we get the code working in 64 bit. Yes, Add-ins from 1750 will work In ArcGIS Explorer 2012. For the 64 bit version you will need to confirm that the add-ins were targetted at "Any CPU"Mark
Sveinung,I sounds like you are encountering two issues.1. The locator you are using crashes when added.2. Searching for a Place using ArcGIS online finds the place, but does not correctly zoom to it. For 1, does the crash occur if you add the following locator.http://www.arcgis.com/home/item.html?id=2762115db7974238aac21d5d0720a769For 2, Does this occur with all places you find? (ex. Search for "Redlands' and it zooms to 0,0)Thanks,Mark
Add-ins used in the configuration also show up on the add-ins tab
Our Oracle-based SDE servers use user-schema geodatabases but apparently that connection type is still unsupported.
....In build 2500 it does not find coordinates at all - it only says "No results found. The place you typed can not be found."My last problem:When use the "Manage locators" under ArcGIS explorer options, ArcGIS explorer crashes immidiately if i try to choose one of the exixting locators.
We have repro cases for this in house and will address for the next release.We have reproduced the find issue by changing language locale to one that use comma in place of decimal. The Find functionality is not handling this correctly.
Nathan,Yes, we do listen to users and customers. In a future version of ArcGIS Explorer (post 2012) their likely will be changes to the available symbols and the user experience for working with them. We have thousands of enhancement requests and software ideas in our database; often the requested enhancement is the most important issue for the person that submitted it. We are well aware that when we do not address an issue, the person that submitted it will be disappointed, and we do not take this lightly. Our users' needs are important to us too! We have the challenge of prioritizing all of these requests against one another and defining a project to address the requests in a reasonable time frame. We also have to look at the ArcGIS Explorer Desktop product and weigh whether the requested functionality is a good fit. This is particularly true of functionality that exists in other Esri software products. ArcGIS Explorer Desktop is not a copy of ArcMap or ArcGlobe. ArcGIS Explorer is meant to be complimentary software for visualizing content created by ArcGIS Desktop (ArcMap, ArcGlobe, ArcScene) and ArcGIS Server. It's primary role is to allow those who do not have ArcGIS Desktop to work with and view the content created by those who do have ArcGIS Desktop. ArcGIS Explorer Desktops availability and price point (free download) lowers the bar for accessing / viewing ArcGIS content.ArcGIS Explorer does have capabilities for viewing "raw data"... shapefiles, geodatabase, rasters, text files, but admittedly there is not a strong cartographic toolset for defining how this data should be displayed (ex. symbolize by attribute). At this time ArcGIS Explorer map authoring is focused on assembling content that has already been cartographically rendered (ArcGIS layers, Services, Web Maps). As ArcGIS Explorer evolves the functionality and user experience in this area could change.Your enhancement requests are important to us and will be considered as we continue to enhance existing software and create new software products.We do have requests for specific symbols and symbolsets in our user requests database.Thanks,Mark
We are planning to upgrade our organization from AGX 1700 to AGX 2500. Scoping out the path we see a few problem areas. We have in the neighborhood of 3000 users.So we plan to support the coexistence of 1700 and 2500 for at least a quarter. .....
